Author Topic: Manual Playlists won't save order  (Read 1030 times)
Versiris
My playlists won't save their manually created order. As soon as I switch away to a different playlist, the order goes random. I can fix it by going to "List -> Restore Natural Order" but as soon as I close MusicBee or switch to a different playlist it breaks again.
Windows 10 Pro
MusicBee 3.2.6765
Versiris
Can someone please address this? I've reinstalled a fresh copy of musicbee on a new computer and this problem still occurs. It was fine for awhile then it just started one day, I didn't change anything.
i expect you have set a sorting order on the playlist.
Right click on the column header bar/ Sort By/ and tick Manual Order
Versiris
Oh my god that fixed it, thank you so much!!  :o  I must have accidentally right clicked and messed it up, which explains why the problem appeared out of nowhere. Thank you again!
