Author Topic: KaraokeShow - a desktop lyrics  (Read 12720 times)
samlangten
KaraokeShow is a desktop lyrics displaying plugin for MusicBee. Dynamic and static lyrics displaying are supported.
I have completely rewritten this plugin and remove complicated framework to make this plugin focus on lyrics display. Compared with last version, these new features have been added:
* Line count of lyrics is customizable.
* Sliding mode(Karaoke mode) can be disabled.
* Resizable window in sliding mode.
* Customizable shadows while painting lyrics.
* Lyrics can move automatically if window is too small in sliding mode .
Download Link on Github Releases
Installation:
Notice: If you have installed old version of KaraokeShow, you may need to delete KaraokeShowPlugins folder in MusicBee plugin folder because these files are useless. Old setting of KaraokeShow will not be imported so you may need to customize plugin again.
Unpack KaraokeShow.zip and put mb_KaraokeShow.dll in MuiscBee plugin folder.
Enable KaraokeShow by clicking "View - Karaoke Show" menu item. It will retrieve lyrics from MusicBee, so make sure that there is an available lyrics retrieval plugin for MusicBee.
This plugin is still under development. You can issue bugs or wishlist on this Github repo.
Last Edit: April 16, 2020, 05:26:35 PM by samlangten
lux1o
i installed this plugin
but
how to make it start?
thanks
mcool
I really like your plugin.
I'd like to have four lines of text instead of two
samlangten
but
thanks
plugin can be enabled by "View - KaraokeShow"
samlangten
Thanks for your suggestions. This feature has been implemented in the latest release.
diego
yst
thanks
Last Edit: February 21, 2021, 11:14:22 PM by yst
irshjet
I downloaded this addon, and it shows in the view tab, but it wont allow me to click on it, and a gray box comes up for about 2 seconds and disappears, is there something else I can do to get this to work?
MarcBee
I have exactly the same problem:
It shows in the view tab, but it wont allow me to click on it, and a gray box comes up for about 2 seconds and disappears. Would be great to get a suggestion on how to make it work, love the concept :)
arbor_mute
Hi, this plugin malfunctions when there are multiple timestamps.
For example, the part of the lyrics of one of the songs of mine are as follows
[01:46.87][03:13.08]그대의 따뜻한 두 눈을 바라볼 수 있게
[01:53.85][03:19.53]언젠가 내가 지쳐버리면
[02:00.81][03:26.50]남는 건 기억 속의 그대뿐
there are two timestamps for each line but the plugin does not display the line for the second timestamp.
could you please update this,,?
