Author Topic: Elemental  (Read 33944 times)
alec.tron
Haha, please be kind to my delicate skin ;-)
I'll try to... dialed it back to useable levels, and re-using your orange:
<root dependsOn="Elemental.xmlc">
<colours id="Default">
 <element id="Player.Wavebar" bg="54,54,54" fg="68,68,68" fg2="111,88,66" />
 <element id="Player.Wavebar.Inner" fg="42,42,42" fg2="245,124,3" />
</colours>
</root>
That'll do for now for me.
c.
alec.tron
One oddity still - the Playlist Explorer, which I use heavily, has a slightly different background grey, i.e. 54,54,54, similar to the "Library Explorer" which pops out from left on hover. But, all other Music Explorer panels use a 48, 48, 48 grey....
I can't find a Playlist Explorer panel explicitly mentioned in the sample xml... any idea how/where the Playlist Explorer panel bg setting would live ?
Cheers.
c.
Are you using a colour piker on the Sample Skin?
That would tell you it uses the same colour as the library explorer panel:
<element id="Panel.Body.Default"
watdub
Thanks for this skin.  The album covers/photos really 'pop' (albums and tracks view).
I've just 'wasted' an half hour scrolling up and down through the album photos reconnecting album covers with old memories  :)
That's half an hour well-spent.
Men in chairs smoking cigars or scrolling albumart in MusicBee don't cause wars...
Johan_A_M
This is a fantastic skin, thank you Hiccup, I really love it! One question (sorry, I can't do a screenshot right now): When tagging multiple files with different e.g. genres, the dropdown menu does not have any visual checkboxes. Instead, I think the text changes color on mouse-over. Is this by design or a minor glitch?
What location is this?
Docked tag editor? Floating tag editor, sidebar editor? Somewhere else maybe?
Johan_A_M
It's at least in both the vertical tag editor as well as the Edit window. It's when you see "Mixed" in a tag and click the arrow to pick one or several. I suspect this is by design, just curious. I'll make a screenshot later when I'm at the correct computer, if not for anything else then at least for future clarity.
Take your time.
My eyes are a bit tired, my display set to very low brightness/blue light, so I'm going to take a look at this with fresh eyes probably tomorrow.
Thanks for reporting.
Ah yes, I see what you mean.
I'll see if I can change it, but it might be a bit difficult because it shares the colour of similar elements at other locations.
And since it is a low contrast grey skin, and small deviations in brightness is pretty much the only thing I can toy with here, this might require a new colouring element that does not yet exist.
I'll see what I can figure out one of these days.
Johan_A_M
Don't put too much time into this, I was mostly curious :)
Updated.
- Fixed a bug when having the player bar on top and tabs in the caption bar.
- Added icons for drives and devices. (they will only display with MB 3.4 which is at the moment not yet available as a stable release)
@Johan_A_M,
The issue with the invisible check-boxes has not been fixed. I've put out a skinning feature request to make it possible to hopefully address this in the future.
Johan_A_M
Updated.
@Johan_A_M,
Great news, I still find this skin to be my absolute favourite!
Updated, minor tweaks.
This is now also fixed.
Thanks Johan_A_M for reporting.
(Note that this will only be fixed for MusicBee 3.4+ which is not yet available at this moment.)
Johan_A_M
Great, thanks!
