Author Topic: sound  (Read 546 times)
rradams35
 :( I cannot get sound on my Bee
Edit > Preferences > Player > check your output and your sound device
Check out the MusicBee Wiki.
If you just installed the latest windows 10 update, it can disable the installed audio driver as it did on my machine. You will need to re-install the audio driver from the device manufacturer
