Author Topic: V3.2.6827 Syncing to Creative ZEN  (Read 5348 times)
chrisjj
Much of MB V3.2.6827 sync functionality works with the Creative ZEN portable device. Here's some info you may find useful.
1) To get MB to access a ZEN, you must first set Preferences, Devices, [✓] detect MTP devices.
2) MB's default device config for a Creative ZEN (Music, Settings) is less than ideal e.g. excludes playlists.
I recommend:
a) In Device, Music, set [✓] synchronise playlists
If you don't want unplaylisted tracks too, set [✓]synchronise music.
b) In Device, Settings:
 * set (*) preserve folders and filenames
     This is to avoid this bug.
 * set playlists path: My Playlists\
 * set save as format: PLA.
For safety, I also set:
 [✓] delete tracks that are not on the auto-sync list from the device
 on the fly conversion
  [_] split files with a cuesheet into individual tracks
 artwork storage
  (*) do not copy artwork.
That makes:
Note: If you need to restore your device config to the default, unplug the device, in Preferences, delete it, and plug it in.
3) Issues
* Sync to MTP device that already contains some of the same track files fails and crashes the device. Workaround: first delete all files from the device .
* Playlists synced by MB show as zero length, which doesn't stop them playing but causes interoperation fails with our programs.
* Preview's folder paths are often incorrect but the actual paths on the device are correct.
* On the device Music node, Folders fails to show correct path(s).
This issue found on a previous version might be present still:
* Playlist sync can fail with "Unable to find the specified file".
Last Edit: October 07, 2018, 08:56:42 PM by chrisjj
