Author Topic: Musictracker - Pidgin plugin  (Read 2267 times)
Azazel
Should be possible make some function that send notification what im listening to pidgin. Im using musictracker plugin https://code.google.com/p/pidgin-musictracker/
ferongr
Well, I use "Send to clipboard" with a global hotkey. Since musictracker seems to be an all encompassing project, you could always open a ticket to request Musicbee support and point them to the API
i'm pretty sure MB can work with pidgen - could you try doing a search on this forum as i recall someone gave instructions for it
Azazel
Its fine to use hotkey, but im interesting in automatic notification. Xmpp protocol (jabber) is using it http://xmpp.org/extensions/xep-0118.html
But seems that working. I was confused because my status was still unchanged but other side confirm that status is actual.
