Author Topic: CTRL+Shift in text fields  (Read 945 times)
Maith
Is it possible to support CTRL-Shift in the search window to delete whole words like expected.
When I try that combination in text fields, I get another character, which I tried to copy-paste in between the parentheses "".
Or is that possibly an OS thing?
Version: 3.2.6827
Running on Windows 10 Pro 64bit (10.0, Build 17134)
If you meant Ctrl-Backspace then I have put some handling in for the next v3.4 update
