So I decided to trial Roon for a couple weeks, and one of the most intuitive features I found was the way it handles hyperlinks in its user interface. I wonder if MusicBee might be able to do something similar.
At the moment you can for example right click an album to activate the context menu, and then select the option to see more by that artist. What if instead you could simply click the artist's name as it appears under the album cover or in the expanded menu to instantly filter the main panel with all albums by that artist? Much in the same way things like genres, years, composers, etc. could also be clickable links. Thoughts?
