I'm using version 10.6.3 of iTunes.
When I scanned for new songs with the first install of MB, the start time worked just fine.
However, I uninstalled and then reinstalled Music Bee once.
I wanted to see if I could resolve another bug by doing that.
However, now when I scan new files from the iTunes library,
the start time of the songs does not import.
The player starts at 0:00
When I change the start time manually in MB, there is an error message
that the file is being used by another process.
Do you recommend I use the latest version of iTunes?
Will that help?
Thank You
I'm learning how to use Music Bee!
Your program is wonderful.
