I have recently purchased a Devialet Pro 140, and have been using it with a demo of JRiver, it works and sounds really well.
I discovered a few days ado MusicBee.
Its UI is really much more pleasant than any other software that I have reviewed during these days, but I have encountered a problem.
After installing MusicBee 3.2. Update 1 and the Asio driver from Devialet, I selected DSD on DoP mode, and could play the DSD64 files perfectly. But after a few hours listening to DSD64 and FLAC files, when I went back to a DSD64 file, I could no longer hear it, instead of the music I heard a white noise, I uninstalled and reinstalled MusicBee, the same with the Asio driver from Devialet , and there is no way. I just managed to hear it again, after doing a new installation of Windows 10. But after a few hours it happened again. I think it was after trying to listen to a DSD128 file, Devialet does not accept these files.
Now the only way I can listen to DSD64 files is if in the player configuration, I select the Devialet Asio Driver, but convert DSD to PCM, not DSD in DoP mode.
I am using a Laptop connected to the Devialet wit an USB cable.
Has anyone found with the same problem?
thanks for your comments
