Author Topic: Issue about scrolling with touchpad  (Read 2560 times)
thetmdth
Hi all! I'm Tommy.
ufabet
So I'm scrolling in the library when view mode is set to "Artists" and "Album covers" is just too fast. It's impossible to control it as just a few movements on the touchpad will take me to the bottom/top of the library. This behavior happens even if I adjust the touchpad sensitivity. In "Tracks" and "Album and Tracks" modes, scrolling is normal and respond to adjustments of the touchpad sensitivity. I'd like first someone check on his machine before reporting this as a bug. I suspect the problem is related to scrolling graphic heavy elements as the album and Artist view display thumbnails.
I'm using an Asus Zenbook ux410ua, with windows precision touchpad.
สมัครufabet
Any help would be greatly appreciated.
Last Edit: August 23, 2018, 12:47:15 PM by psychoadept
zkhcohen
It's because it scrolls row-by-row on default.
Hold the alt key while scrolling.
beeyak
I just installed Musicbee and had the same scrolling issue; just wanted to you know this answer was useful.
Also, 'ctrl' in conjunction with touchpad scrolling gesture allows an easy resizing of album icons which also further facilitates preferred scrolling behavious.
