Author Topic: exporting playlists  (Read 2002 times)
martux
Hello!
Today I discovered the feature to automatically export playlists and also have the file-path adjusted automatically. This is really nice for me to export to my Android cellphone. The only problem for me is that I still have to use a text editor to replace the .flac extensions to .mp3. I have to convert those due to space limitations. It would be most lovely to have a "search and replace" feature, so this could also be automated. Pleeease? :)
You can export playlists automatically when you sync, and if you're converting to mp3 in the process they should reflect that
martux
I don't do it in the process. Whenever I add some flac files to my collection, I also add them manually to a second folder as mp3. That folder goes to my cellphone (Automatically synced with foldersyncpro).
So far using my favorite songs, requires me to heavily edit the exported m3u (file path, unix/windows slashes and of course renaming the flac files to mp3). Everything but the last part is automated now with music bee.
