Author Topic: Album selector in Album Covers view  (Read 2100 times)
When "fit artwork to the size of the panel" option is enabled, album selector draws the selector over the fields part too and clearly shows which albums are selected.
But when the option is disabled, it's up to the selector color and it can't work for every color of the album covers.
How about drawing the selector over the fields part too all the time?
Last Edit: August 04, 2018, 04:13:27 PM by redwing
Noticed this was implemented for v3.3.
A lot easier to tell which albums are selected. Thanks!
Noticed a visual glitch from the bottom line of lowlight selector.
To reproduce, select an album, select another node in left navigator, select the original node again.
yes i can reproduce this and its fixed now
Last Edit: December 01, 2018, 10:40:55 AM by Steven
Another minor bug.
After selecting albums in top row, if you scroll down a bit and go back, then the top border of the selector disappears. It happens only with top row and pressing F5 fixes it.
