Author Topic: Tag's copy  (Read 1011 times)
corion
hi !
just a little issue :
when I copy the tags from an album to an other (when I update the files from mp3 to flac for example), all the tags are well copied, except the notation ; so I have to re-note each track, one by one if they are all different ...
did you already met this ? is it a known bug ?
you are using the musicbee file converter to convert mp3 files to flac, and the comments field is not carrying across from the .mp3 file to the .flac file?
if thats what you are saying i cannot reproduce the issue
corion
well, when I select an album and press CTRL-C, then select another one and press CTRL-V, all the tags are copied on the second album, title, artist, lyrics, cover, and so on, except the notation (up to 5 stars) ;
I don't know if it's normal, or a bug ;
its normal.
assign the hotkey for "Edit: Copy Tags, Artwork, Play Counters and Rating"
