Author Topic: Can't play a tracklist when Tempo Control is enabled  (Read 1946 times)
-L0Lock-
Since I've updated to 3.2.6756 (and tested on 3.2.6760 too), on a Windows 10 pro computer :
When Tempo Control is enabled, the tracklist stays blocked at the very end of the first played track.
So it just looks like this :
It seems that it doesn't matter what value is set in the Tempo Control (i tested randoms negative and positive values as well as 0%).
Musicbee 3.2.670
W 10 pro
i7 4790
16 Gb RAM
GTX 970
The link to the latest bass_fx.dll from un4seen that Steven mentions which includes the tempo bug fix (version 2.4.12.1) is here: https://www.un4seen.com/download.php?z/0/bass_fx24
The changes the newer version(s) include are described at https://getmusicbee.com/forum/index.php?topic=25133.0 .  I'm just indicating this in case some of the other changes affect your own usage of Tempo and other DSP.
Last Edit: July 25, 2018, 10:23:10 PM by sveakul
-L0Lock-
Ok thanks, it works with the latest bass_fx.dll from un4seen.
Would this lib de updater for the next musicbee version ?
