The dynamic digital time indicator that follows the mouse cursor inside the spectrogram is great! Thanks! Um, but may I mention just two things...
Current behavior is that when clicking into a seek point within the image, the song correctly jumps to that time point and continues playing as expected, but the MusicBee elapsed/total track time indicator in the corner will freeze, jumping to the correct time only when the cursor is moved out of the spectrogram panel. Is it possible to synch the spectrogram seek point with the MusicBee timer so that the latter updates immediately? This is easier to see than to describe. And, to see how far out on a limb I can crawl, would be possible to have the mouse cursor while in the spectrogram retain the normal arrow pointer as it did in 1.6x instead of the "funky finger"?
I keep the plugin's own seek bar disabled as it's not needed with your new update, frees up a tiny bit more real estate, and I prefer to keep the MusicBee one available. And with a dark (black) skin you can't see it anyway.
Thanks for your work on this, and for being so open to user requests! Again, thanks for the "placeholder" option that allows the space to be used for a user-supplied image when playing radio streams, works perfect and much appreciated. If it any point you feel like these requests (from me or anybody) start to kludge up the core operation/intent of the plugin, "just say NO!"
