thanks my brotha !!!
work !!
Glad to help.
I noticed that a track was missing from an album, and I searched for the title in MB, but it would not find it. Even searching for the filename would fail. I have auto-import enabled on my music folder, and despite this, and several re-scan attempts, the track does not show up in MusicBee.
I had to spam the track several times by dragging it from my folder into my library and a playlist, and eventually I found it, but it did not have ANY tags. What you suggested helped.
It's still insanely strange because other players like Foobar recognize the tag of the track without problems. This nearly gave me an aneurysm..
I just tried this with a clean MB portable install, and it actually recognizes the tags and all of the tracks on the album. Something must be wrong with the settings file of my main MB installation..
I think Foobar rereads the tags each time - MusicBee maintains a library in a database. If you change the tags outside of MB, you need to rescan the files to update the library database with the new values.
As for the missing file(s), do you have yourself set to put duplicates in your Inbox and, if so, are they in your Inbox?
I don't drag and drop to add to the library, so I'm kind of clueless as to the process or how it works or what could go wrong. I always import to Inbox and then make any adjustments and then right click -> Send to -> Music Library. I've found this method to work flawlessly. That'd be my only suggestion, although I don't know how it would fit into your process.
I also only ever do tagging before importing to MB to avoid tag / library mismatch situations. Again, don't know how that would fit in anyone else's process, but it works for me and MB seems happy with it because I don't seem to run into the problems a lot of drag and drop adders do. Food for thought.
I do:
Tag in MusicBrainz + MP3Tag
Import
Organize
Adjust as needed from within MB
Add to Library
