Author Topic: I can't add any new skin for Theater Mode (.zip)  (Read 792 times)
SpaceKeeper025
I'm currently using the latest Windows Store version. I tried to add theater mode by View > Theater Mode > Add skin, but I can't add any zip files, I can only add xml files and leave out all other files in the zip file. But I can still add zip files for main player skin. Please fix it soon :(
Update: There is no error message. The skin just doesn't show up in the Theater Mode list when I add zip file
Last Edit: July 08, 2018, 10:15:57 AM by SpaceKeeper025
Its working fine for me. However, only the Compact Player and the main View/ Theater Mode function will use the added skins. If you are using the Now Playing Bar or the Now Playing tab in the main panel then there isnt a way to add embedded skins
