Author Topic: Album Cover  (Read 1138 times)
Nighthawk_NL
Hi Steve,
Can you please add Album Cover in the Set Display Field. So you can easily see what the Dimensions is of the Album Cover e.g. 500x500 ?
Many thanks in advance.
Depending on which view you're using, you can see the image size by hovering the cursor over the image.
Tools/ Artwork/ Album Artwork Manager can show the picture dimensions in the main grid
Nighthawk_NL
Hi Steve and Phred, thanks for your quick response. I am aware of the hoovering but that consumes a lot of time when you have a lot of records. And Tools / Artwork is indeed a good option. Thanks. But I still like to see the dimensions also in the main display panel. I hope this is possible.
