Author Topic: Task bar buttons should not be mirrored when the OS uses right-to-left layout  (Read 915 times)
Stamimail
I downloaded the portable version,
MusicBeePortable_3_1_Update3.zip
I'm using Windows 7 Hebrew OS.
I can see MuiscBee has the same issue I've had with MPC-HC (problem fixed). The buttons of the taskbar thumbnail preview are reversed.
https://trac.mpc-hc.org/ticket/2167
https://github.com/mpc-hc/mpc-hc/commit/d4264fd456a4919e5de8961da7e8372559879100
According to my experience, the best way to handle and see how it looks like in RTL systems, is to achieve a RTL OS in virtual machine. Use VMware.
