Author Topic: Synchronization Failed  (Read 698 times)
in7327
MusicBee v3.0.6335.15398 (Win10.0), 10 Jun 2018 12:57:
   at
You're using an extremely old version. I suggest upgrading to at least 3.1. Better still go to 3.2. Lots of fixes and improvements have been made since the version you're using.
