Author Topic: Cannot Rename Playlists  (Read 1752 times)
atreyuu2003
Have not found anything about this issue anywhere. I am just getting acclimated to MusicBee, since WMP is a thing of the past (Microsoft shooting themselves in the foot again), and so far it's awesome. However, I cannot rename playlists. I have tried both ways, doing a slow-left-click and right clicking and selecting "Rename." After I type in the new name of the playlist, it just reverts back to what it already was; highly frustrating. Has anyone got a fix for this issue? Thank you, kindly, in advance.
Troy
What happens if you launch MB as administrator? If that works, I'd suggest using the portable install version of MB and installing to a Windows non-system path.
atreyuu2003
Thanks, but I already tried that, and it doesn't work. Should have said that at the start. Sorry, man. Is this an isolated incident, since I haven't seen anyone else with this complaint in any of my Bing searches.
Yes.
Yes again.
What version are you running? Installed, portable, or from Windows Store?
Then can you update your playlists? Probably not.
Try moving your playlists folder to another place in Preferences> Library in case it's a permission issue.
Also make sure no other running programs lock the playlists.
Mauser69
I do not run as administrator, and I generally have no problems renaming a playlist.
I say "generally" because I did see this once or twice.  Not really sure why, but I started making sure I hit enter after I finished typing the new name, and it has always taken since then.
atreyuu2003
I can update my playlists, just can't rename them.  I'll try some of the other things you mentioned and see if anything works.
atreyuu2003
Found it! It was the "Enter" button. You can't just click to the side after renaming like in WMP. You must hit the "Enter" key for it to take.
Thank you, all!
