Author Topic: music wont sync with iPhone SE  (Read 2663 times)
cke11y
Hi there, I am new to musicbee so please go easy on me  :-X
I've started using it because I'm using a NAS drive and have 230GB of music and itunes couldn't populate it - in a week it only got to 110GB
Musicbee is ace it loaded all my music in less than 10 minutes.
I'm now trying to add some music to my iphone (have followed plugin instructions) but all i get is:
"synchronisation failed"
and
"The storage folder 'iphone\ck\internal storage\music' no longer exists and may need to be changed in the device synch preferences"
Any idea what I should do to fix this?
I did do a screenshot but I cant add images here?
Thanks in advance!
You should post this directly in the thread for the plugin you're using.
cke11y
I'm now trying to add some music to my iphone (have followed plugin instructions)...
What thread would that be then?
You stated that you followed the plugin's instructions. You should post it in the thread of the plugin which you downloaded. Some plugin authors only follow their plugin's thread and not the entire forum. Posting your issue in the plugin's thread gives the author a chance to see your post. You don't state which plugin you're having issues with, but find the thread for whatever you downloaded, and post your issue there.
cke11y
mopmra
Last Edit: February 19, 2024, 01:04:09 AM by mopmra
