On several Icecast server ogg-wrapped FLAC streams for example Rondo Classic Klasu
http://rondo.iradio.fi:8000/klasu.flac) and Frequence3
http://rod.frequence3.net/frequence3.flac) MusicBee shows the bitrate as "128k".
This is must be due to MusicBee pulling that info directly from the Icecast server bitrate header "icy-br", which incorrectly shows "128" as its value. For instance, the first example's header log looks like this in the AIMP player:
HTTP/1.0 200 OK
Server: Icecast 2.4.2
Date: Sun, 27 May 2018 20:41:56 GMT
Content-Type: application/ogg
Cache-Control: no-cache
Expires: Mon, 26 Jul 1997 05:00:00 GMT
Pragma: no-cache
icy-br:128
ice-audio-info: ice-samplerate=44100;ice-bitrate=128;ice-channels=2
icy-br:128
icy-description:Classical music for modern listeners, 24/7
icy-genre:Classical music
icy-name:Rondo Classic Klasu-flac
icy-private:0
icy-pub:1
icy-url:http://www.rondolehti.fi
However, AIMP correctly displays the actual FLAC bitrate in its running line:
Can MusicBee also be made to display the actual bitrate instead of using the often erroneous info from the "icy-br" server stream header?
Thanks for your consideration.
