Author Topic: Volume Analysis adds an empty tag in FLAC files with a "16" value  (Read 1058 times)
theG
Since the last few versions of v3.2 (currently v3.2.6721), when I do a volume analysis on FLAC files, MusicBee adds a nameless tag with a value of "16".
That's the Bit Depth.  MusicBee adds this value now when scanning lossless files.  Check this forum thread for display options:
https://getmusicbee.com/forum/index.php?topic=24661.0
This version will no longer write the unnecessary info for new files. You would need to manually delete using mp3tag if you want to remove existing ones
http://musicbee.niblseed.com/V3_2/MusicBee32_Patched.zip
Thanks for the report, theG!
Just cleared up the field using mp3tag. In my collection, it first started with albums analyzed in May 11. It might have started 2 days earlier, but albums in May 8 were clear.
Open those tracks in mp3tag> select all and right click> Extended tags> find a blank field at the top and remove it> save.
[edit] No, it was earlier than that. It first started in May 3.
Last Edit: May 28, 2018, 06:02:24 PM by redwing
