Author Topic: Playback issue  (Read 596 times)
emmecì
This issue still bothering me...  let's suppose i've a flac 24/96 file and a capable dac (audio 2.0). With other apps, i pick wasapi and the playback will always match what i play. This will never happened with musicbee.
I also have issue with wasapi playback. For example, sometimes playback never happens until i click on the seekbar.
I tried ASIO and it works until i quit musicbee. Once i go back, i got bass buffer lost error or simply playback error. I've to restart pc (or to power the dac off) to make it work again.
The only way to have no issue, is to use directsound. With other players, I've no problems.
Any thoughts/suggestions?
Turn off crossfading (and maybe? skip silence).
Cross fading definitely converts to 16/44.1, though.
emmecì
Thanks so much: both removed and now seems to work.
