Author Topic: LyricsReloaded (Updated)  (Read 167137 times)
Just throwing this out here, not even sure if it is something the plugin or a regex could address, and I also have no idea from what lyrics provider it was sourced:
I fought against the bottle,
But I had to do it drunk –
Took my diamond to the pawnshop –
But that don’t make it junk.
So instead of e.g. don't  you will get donât.
For another song I got itâs instead of it's.
A quick google hints towards this being related to things like PHP, UTF8.
Maybe somebody with some coding talents has an idea about this?
A second thought:
I was assuming this was retrieved and output using the plugin.
But I now wonder about that: the plugin does not fully disable MusicBee's internal lyrics retrieval, does it?
So if you press 'search next provider', it could either present a result from the plugin, or from MB's internal engine?
If that assumption is correct, this could be completely beyond what the plugin could fix?
LazR
I also fixed Musixmatch, and added the minor tweaks to crisp's fix for Genius.
For the sake of easy copy-pasting, I'm putting them both here.
Genius:
variables:
    artist:
        type: artist
        filters:
        - strip_diacritics
        - lowercase
        - [replace, "!!!", "chk-chik-chick"]
        - [replace, "&", "and"]
        - [regex, '(?<=\W|\s)+(feat.+|ft[\W\s]+|(f\.\s)).+', ""]
        - [regex, '\.+|,+|(\W+(?=$))|(^\W+)', ""]
        - [regex, "'", ""]
        - [regex, '(?<=[a-z0-9%])[^\sa-z0-9%]+(?=[a-z0-9%]+)', "-"]
        - [regex, '((?<=\s)([^a-z0-9\s-])+(\s|\W)+)|((?<=\w)([^a-z0-9-])+(\s|\W)+)', " "]
        - [strip_nonascii, -]
    title:
        type: title
        filters: artist
config:
    url: "https://genius.com/{artist}-{title}-lyrics"
    pattern: ['<div class="Lyrics__Container.*?">(?<lyrics>.*)<div class="Lyrics__Footer.*?">']
post-filters:
- br2nl
- strip_html
- utf8_encode
- entity_decode
- clean_spaces
Musixmatch:
variables:
    artist:
        type: artist
        filters:
        - strip_diacritics
        - lowercase
        - [regex, "'", ""]
        - [regex, "/", " "]
        - [regex, '\s&(?=\s)', " "]
        - [regex, '[^\sa-z0-9]\s*', ""]
    title:
        type: title
        filters:
        - strip_diacritics
        - lowercase
        - [regex, " '|' |/", " "]
        - [regex, "'", " "]
        - [regex, '\.+|,+|/+|(\W+(?=$))|(^\W+)', ""]
        - [regex, '\s&(?=\s)', " and"]
config:
    url: "http://www.musixmatch.com/lyrics/{artist}/{title}"
    pattern: ['<p class="mxm-lyrics__content.*?">(?<lyrics>.*?)<div [^>]*"lyrics-report".*?>', s]
post-filters:
- [regex, "<script.*?</script>", "", s]
- strip_html
- utf8_encode
- entity_decode
- clean_spaces
(I would think this would also fix Musixmatch-Asian, but I'm not a good tester for it. If anyone wants it, I can add that too.)
Oh my gosh, thank you so much Redearth. The only issue I am noticing is where ads are placed between lyric sections (ex. [chorus] [verse] etc), it is not adding an extra space. And it only happens on some songs not all.
Here is a screenshot detailing it -- https://imgur.com/a/PFBA6eJ
Is there a way to get that fixed?
Redearth
You would need to fix the source, or be okay with inconveniences like this. This plugin just brings in whatever html/script is on the page, not the page you see. (Always view source.)
You'd have to add a post-filter regex that adds a newline in front of lines that begin with "[" that also don't have a blank line before them.
Last Edit: November 10, 2021, 07:21:20 AM by Redearth
It pains me to say it, but I think the new Genius yml is no longer pulling lyrics--can others confirm?  If so, the Bat Beacon goes out to crisp and Redearth for a fix!
crisp
This is an odd one. The way I zeroed in on the solution before was (1) making the config pattern as permissive as possible and turning off all the post-filters to dump the whole HTML in the MusicBee lyrics pane, (2) finding the tags that surrounded the lyrics (i.e., Lyrics__Container and Lyrics__Footer) and modifying the config pattern with them, and (3) iteratively add post-filters to get rid of HTML tags, bad formatting, etc. In this case, I'm not even getting any HTML when I use config pattern '(?<lyrics>.*)' (which I think should just capture the whole page?). I do get a "Lyrics found" printout in the log file though.
My first instinct was to curl an example URL from the log file, which got me a tiny HTML telling me I got redirected. If I uppercased the first character of the artist's name (so `curl https://genius.com/Artist-title-lyrics` instead of `curl https://genius.com/artist-title-lyrics`), curl returned the whole page as expected, but doing the same thing on the plugin side didn't really help. Also tried building the plugin myself to add some debug prints, but it looks like it depends on an old unavailable (?) version of YamlDotNet, so no luck there either.
@crisp:  I'm guessing that you haven't found a way to restore this yml despite the data I PM'd you?  If not, thanks anyway for making the attempt.  I know it's bound by the limits of the dll itself.
crisp
Well this is embarassing, I wasn't seeing lyrics because at some point during debugging I removed the 's' flag from the config pattern.
Thanks sveakul, your message pointed me in the right direction, here's the updated yml:
name: Genius (2021-11-30)
variables:
    artist:
        type: artist
        filters:
        - strip_diacritics
        - lowercase
        - [regex, "'", ""]
    title:
        type: title
        filters: artist
config:
    pattern: ['<div id="lyrics-root-pin-spacer">(?<lyrics>.*)<div class="Lyrics__Footer-sc-', 's']
post-filters:
- br2nl
- strip_html
- utf8_encode
- entity_decode
- clean_spaces
- [regex, '[\[\{].{1,75}[\]\}]', ""]
- [replace, "\n\n", "\n"]
- trim
THANKS, crisp, this is working terrific again!  I think it may now bypass the "gotchas" that they throw in occasionally as it works more on the "root."  I did notice that it seems to strip ALL the empty lines between verses/sections, but I removed the - [replace, "\n\n", "\n"]  line from the post filters section (and for the heck of it rolled back - [regex, '[\[\{].{1,75}[\]\}]', ""] to - [regex, '\[.{1,75}\]', "") and it displays fine for me;  just personal taste, others may choose to use the originals.
You are a gentleman and a scholar, and thanks again for fixing Genius for us.
For anyone who wants to use the update provided by crisp, and is too lazy to make sveakul's changes...
variables:
    artist:
        type: artist
        filters:
        - strip_diacritics
        - lowercase
        - [regex, "'", ""]
    title:
        type: title
        filters: artist
config:
post-filters:
- br2nl
- strip_html
- utf8_encode
- entity_decode
- clean_spaces
- [regex, '\[.{1,75}\]', ""]
- [regex, '\n{2,}',"\n\n", 's']
- trim
EDIT: Fixed typo and added line to get rid of the double line spacing per crisp's reply immediately following.
Last Edit: December 01, 2021, 07:36:56 PM by phred
crisp
Thanks phred, if this doesn't work for anyone, it's just a missing square bracket at the end of the last regex. And if you wanna get rid of the leftover double newlines, this can go right after that regex:
Sorry, my fault not phred's, that will teach me not do copy/paste operations when I'm falling asleep.  crisp, thanks for the extra regex code that does indeed remove DOUBLE blank spaces that slipped by my edit.  For the sake of completeness, below is crisp's new full genius.yml code that includes the bracket I missed and the extra regex to be added to prevent the double blanks:
variables:
    artist:
        type: artist
        filters:
        - strip_diacritics
        - lowercase
        - [regex, "'", ""]
    title:
        type: title
        filters: artist
config:
post-filters:
- br2nl
- strip_html
- utf8_encode
- entity_decode
- clean_spaces
- trim
Moshi_
  • http://www.last.fm/user/Moshi_
I've got a different problem. Bracket words are not showing at all. Any way to fix this? Using sveakul's edit.
Screenshot:
The bracketed section headers are removed by default, via a contribution to the code from frankz.  Most of us prefer this, but if you want them left there remove frankz's code line below from the rest of the script:
YukiSoul
Can somebody tell me what happen on this LyricsReloaded log?
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Musixmatch
30/12/2021 11:10:49 [INFO] Musixmatch tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://www.musixmatch.com/lyrics/penny-and-sparrow/eloise
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Musixmatch_Asian
30/12/2021 11:10:49 [INFO] Musixmatch_Asian tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://www.musixmatch.com/lyrics/Penny-and-Sparrow/Eloise
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Genius
30/12/2021 11:10:49 [INFO] Genius tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://genius.com/penny-and-sparrow-eloise-lyrics
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - MetroLyrics
30/12/2021 11:10:49 [INFO] MetroLyrics tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://www.metrolyrics.com/eloise-lyrics-penny-and-sparrow.html
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Urban Lyrics
30/12/2021 11:10:49 [INFO] Urban Lyrics tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://www.urbanlyrics.com/lyrics/pennyandsparrow/eloise.html
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Song Lyrics
30/12/2021 11:10:49 [INFO] Song Lyrics tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://www.songlyrics.com/penny-and-sparrow/eloise-lyrics/
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Teksty
30/12/2021 11:10:49 [INFO] Teksty tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://teksty.org/penny-and-sparrow,eloise,tekst-piosenki
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Smriti
30/12/2021 11:10:49 [INFO] Smriti tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://smriti.com/hindi-songs/eloise
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Letras de músicas
30/12/2021 11:10:49 [INFO] Letras de músicas tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://letras.mus.br/penny-and-sparrow/eloise/
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Hindi Lyrics
30/12/2021 11:10:49 [INFO] Hindi Lyrics tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://www.hindilyrics.net/lyrics/of-Eloise.html
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Cušpajz
30/12/2021 11:10:49 [INFO] Cušpajz tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://cuspajz.com/tekstovi-pjesama/pjesma/penny-and-sparrow/eloise.html
30/12/2021 11:10:49 [DEBUG] Lyrics request: Penny and Sparrow - Eloise - Finch - Oldies Lyrics
30/12/2021 11:10:49 [INFO] Oldies Lyrics tries to load the lyrics...
30/12/2021 11:10:49 [DEBUG] The constructed URL: http://oldielyrics.com/lyrics/penny_and_sparrow/eloise.html
30/12/2021 11:10:50 [INFO] No lyrics found.
30/12/2021 11:10:50 [DEBUG] no lyrics found from Song Lyrics
30/12/2021 11:10:50 [DEBUG] gzip compression detected
30/12/2021 11:10:50 [DEBUG] no lyrics found from Hindi Lyrics
30/12/2021 11:10:50 [DEBUG] lyrics found from Musixmatch_Asian!
30/12/2021 11:10:50 [DEBUG] lyrics found from Musixmatch!
30/12/2021 11:10:50 [DEBUG] no lyrics found from Teksty
30/12/2021 11:10:50 [WARN] The pattern <div class="lyrics">(?<lyrics>[\s\S]*?)</div> didn't match!
30/12/2021 11:10:50 [DEBUG] no lyrics found from Genius
30/12/2021 11:10:50 [DEBUG] no lyrics found from Oldies Lyrics
30/12/2021 11:10:51 [DEBUG] gzip compression detected
30/12/2021 11:10:51 [WARN] The pattern <div class="songbody">(?<lyrics>.*?)</div> didn't match!
30/12/2021 11:10:51 [INFO] No lyrics found.
30/12/2021 11:10:51 [DEBUG] no lyrics found from Smriti
30/12/2021 11:10:51 [WARN] The pattern <p\sclass="text\sclearfix">(?<lyrics>[\s\S]*?)</p> didn't match!
30/12/2021 11:10:51 [DEBUG] no lyrics found from Cušpajz
30/12/2021 11:10:52 [DEBUG] gzip compression detected
30/12/2021 11:10:52 [WARN] The pattern <div id="div_letra"[^>]*>(?<lyrics>.*?)</div> didn't match!
30/12/2021 11:10:52 [INFO] No lyrics found.
30/12/2021 11:10:52 [DEBUG] no lyrics found from Letras de músicas
its showing No lyrics found on lyric floating window.
but in the log, for example in this line,
when i open the link, there is lyrics in musixmatch site but why still "No lyric found" ?
Can anyone help? at least some guess about what is happening here.
https://imgur.com/a/6ayOkU9
