Also, these were in the original and not this new and improved version. I don't know if they're relevant any more.
- [regex, 'googletag.*\);', "\n"]
- [regex, '<!--sse-->', ""]
- [regex, '<!--/sse-->', ""]
- [regex, "’", "'"]
Nice to see you're still keeping you hand in this, frankz. Does this part go in the filters section or the post-filters?
They were in the post-filters.
I'm pretty sure the sse ones are irrelevant now - I put those in because that text was showing up in the lyrics and now it's not, so either the new version fixes whatever I couldn't figure out and fix in a more elegant way the first time or genius no longer includes that.
I think the googletag one is from way back when the original version was first posted in the original thread by the original author of this provider. I don't know if it is needed any more (it doesn't seem like it).
For the plugin update I'll post once I get the time (and permission from crisp and Redearth to use their great works), I plan to use the header replacement from hiccup, the double line to single line from the user suggestion, and the quote character replacement and trim from the original, but not those other old ones as they don't appear to be needed any longer.
