frankz that's cool.
BTW, I noticed that when lyrics are found, and then the window right-clicked and "Search Next Provider" selected, past behavior was that if another one of the plugin's sources had the lyrics also, those would then be displayed. Now, after doing that you just get "No lyrics found", even when more than one source definitely has the lyrics. For example, Switchblade Symphony's "Clown", or Suzi Quatro's "Devil Gate Drive" both immediately find lyrics at Genius (first on my list), but when "Search Next Provider" is done nothing is found, even though MusixMatch has those lyrics also (and will display them if the genius source is un-checked when search is begun). Is that happening by design? Newest version of LRU and MB. Maybe I'm recalling that from when more of the MB built-in sources were active and maybe "Next provider" was actually jumping over LRU?
