Author Topic: LyricsReloaded (Updated)  (Read 164085 times)
Rodo
I'm new to Musicbee.  Just been trying it out and installed this plugin.  After installing it, I ran it and it added lyrics to the selected songs.  Then I closed Musicbee and later re-opened it.  The following error appeared and then Musicbee shutdown.  This error continues to appear each time I open Musicbee and it then shuts down.  I've moved the plugin .dll file from the plugin directory and I can now open Musicbee successfully but the plugin won't work when I then try to install it again.  I have also deleted the log file but this has not helped.  Can someone help?
Error appearing:
An error occurred during plugin startup.  The process cannot access the file
'C:\Users\<user name>\AppData\Roaming\MusicBee\mb_lyricsReloaded\mb_lyricsReloaded.log it is being used by another process.
MusicBee v3.3.7367.38620D  (Win10.0), 19 Jun 2020 12:22:
   at CubeIsland.LyricsReloaded.LyricsReloaded.shutdown()
   at CubeIsland.LyricsReloaded.LyricsReloaded.Finalize()
Rodo
Oh I should have searched this thread before posting.  Just found the issue.  I had two .dll files.  Deleted one and now it's all good.
Thanks for your help Frank.  I found the issue just before you posted about what to do.
frostbyte
Suddenly, when I try to fetch the lyrics they already have the status not found. So I can't refetch them again which worked for some songs in the past. Restarting musicbee doesn't help.
Edit: solved. My network share wasn't unlocked. Forgot to enter password first  :)
Last Edit: July 24, 2020, 11:14:16 AM by frostbyte
RetroGameReaper
For some reason I'm having barely any luck getting lyrics anymore. When I do get lyrics, it's completely at random. I downloaded a separate lyrics program and that works fine, but Lyrics Reloaded doesn't.
What version of MB are you using (Help > About)?
How was MB installed (Store, Installer, Portable)?
Please post a screenshot of your lyrics auto-tagging settings from Preferences > Tags (2)
You're going to need to be more specific about what songs are failing (title and artist **as tagged**) and what it says in the program's log file for these songs (%AppData%\mb_LyricsReloaded\mb_LyricsReloaded.log).  AFAIK all of the sources active in the plugin are working fine.
I'm on version 3.3.7491 P
Hmmm ... I do recall Steven adding Bing for lyrics searches not to long ago. I would make that first on the list of sources. If you don't see it on your current list, I suggest updating to the latest patch version for either 3.3 or 3.4, although it may be a 3.4 thing. For the record, 3.4 is a very, very stable beta. Many of us have been using it for months with no issues.
See my sig for patch links.
He didn't.  You made a yml for it.
Steven added bing for artwork searches.
Last Edit: September 04, 2020, 04:05:56 PM by frankz
I did??!! It must've been with help from you. (Thanks)
<sigh> I knew he did -something- with bing.
Have you considered adding bing lyrics as a provider? I can show you the YML if you're interested. :-)
RetroGameReaper
04/09/2020 11:40:24 [INFO] Song Lyrics tries to load the lyrics...
04/09/2020 11:40:24 [DEBUG] The constructed URL: http://www.songlyrics.com/764hero/check-the-address-lyrics/
04/09/2020 11:40:24 [DEBUG] Lyrics request: 764-HERO - Check The Address - We're Solids - Teksty
04/09/2020 11:40:24 [INFO] Teksty tries to load the lyrics...
04/09/2020 11:40:24 [DEBUG] The constructed URL: http://teksty.org/764-hero,check-the-address,tekst-piosenki
04/09/2020 11:40:24 [DEBUG] Lyrics request: 764-HERO - Check The Address - We're Solids - Urban Lyrics
04/09/2020 11:40:24 [INFO] Urban Lyrics tries to load the lyrics...
04/09/2020 11:40:24 [DEBUG] The constructed URL: http://www.urbanlyrics.com/lyrics/764hero/checktheaddress.html
04/09/2020 11:40:24 [INFO] No lyrics found.
04/09/2020 11:40:24 [DEBUG] no lyrics found from Smriti
04/09/2020 11:40:24 [DEBUG] no lyrics found from Oldies Lyrics
04/09/2020 11:40:25 [INFO] No lyrics found.
04/09/2020 11:40:25 [DEBUG] no lyrics found from MetroLyrics
04/09/2020 11:40:25 [DEBUG] no lyrics found from A-Z Lyrics Universe
04/09/2020 11:40:25 [DEBUG] no lyrics found from Genius
04/09/2020 11:40:25 [DEBUG] gzip compression detected
04/09/2020 11:40:25 [WARN] The pattern <p\sclass="text\sclearfix">(?<lyrics>[\s\S]*?)</p> didn't match!
04/09/2020 11:40:25 [DEBUG] no lyrics found from Cušpajz
04/09/2020 11:40:25 [DEBUG] no lyrics found from Song Lyrics
04/09/2020 11:40:25 [DEBUG] no lyrics found from Teksty
04/09/2020 11:40:25 [WARN] The pattern <div id="div_letra"[^>]*>(?<lyrics>.*?)</div> didn't match!
04/09/2020 11:40:25 [DEBUG] no lyrics found from Letras de músicas
04/09/2020 11:40:25 [WARN] The pattern <p class="mxm-lyrics__content ">\s*(?<lyrics>.*?)</span> didn't match!
04/09/2020 11:40:25 [DEBUG] no lyrics found from Musixmatch
04/09/2020 11:40:26 [DEBUG] gzip compression detected
04/09/2020 11:40:26 [WARN] The pattern <p class="mxm-lyrics__content ">\s*(?<lyrics>.*?)(</span>|<div[^>]*"lyrics-report") didn't match!
04/09/2020 11:40:26 [INFO] No lyrics found.
04/09/2020 11:40:26 [DEBUG] no lyrics found from Musixmatch_Asian
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Genius
04/09/2020 11:40:29 [INFO] Genius tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://genius.com/764-hero-stutter-steps-lyrics
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - MetroLyrics
04/09/2020 11:40:29 [INFO] MetroLyrics tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://www.metrolyrics.com/stutter-steps-lyrics-764hero.html
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Musixmatch
04/09/2020 11:40:29 [INFO] Musixmatch tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://www.musixmatch.com/lyrics/764hero/stutter-steps
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - A-Z Lyrics Universe
04/09/2020 11:40:29 [INFO] A-Z Lyrics Universe tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://www.azlyrics.com/lyrics/764hero/stuttersteps.html
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Cušpajz
04/09/2020 11:40:29 [INFO] Cušpajz tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://cuspajz.com/tekstovi-pjesama/pjesma/764-hero/stutter-steps.html
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Hindi Lyrics
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Letras de músicas
04/09/2020 11:40:29 [INFO] Letras de músicas tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://letras.mus.br/764-hero/stutter-steps/
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Musixmatch_Asian
04/09/2020 11:40:29 [INFO] Musixmatch_Asian tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://www.musixmatch.com/lyrics/764-HERO/Stutter-Steps
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Oldies Lyrics
04/09/2020 11:40:29 [INFO] Oldies Lyrics tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://oldielyrics.com/lyrics/764hero/stutter_steps.html
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Smriti
04/09/2020 11:40:29 [INFO] Smriti tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://smriti.com/hindi-songs/stutter-steps
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Song Lyrics
04/09/2020 11:40:29 [INFO] Song Lyrics tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://www.songlyrics.com/764hero/stutter-steps-lyrics/
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Teksty
04/09/2020 11:40:29 [INFO] Teksty tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://teksty.org/764-hero,stutter-steps,tekst-piosenki
04/09/2020 11:40:29 [DEBUG] Lyrics request: 764-HERO - Stutter Steps - We're Solids - Urban Lyrics
04/09/2020 11:40:29 [INFO] Urban Lyrics tries to load the lyrics...
04/09/2020 11:40:29 [DEBUG] The constructed URL: http://www.urbanlyrics.com/lyrics/764hero/stuttersteps.html
04/09/2020 11:40:30 [INFO] No lyrics found.
04/09/2020 11:40:30 [DEBUG] no lyrics found from Genius
04/09/2020 11:40:30 [DEBUG] no lyrics found from MetroLyrics
04/09/2020 11:40:30 [DEBUG] no lyrics found from Smriti
04/09/2020 11:40:30 [DEBUG] no lyrics found from A-Z Lyrics Universe
04/09/2020 11:40:30 [DEBUG] no lyrics found from Oldies Lyrics
04/09/2020 11:40:30 [DEBUG] gzip compression detected
04/09/2020 11:40:30 [WARN] The pattern <p\sclass="text\sclearfix">(?<lyrics>[\s\S]*?)</p> didn't match!
04/09/2020 11:40:30 [DEBUG] no lyrics found from Cušpajz
04/09/2020 11:40:30 [DEBUG] no lyrics found from Song Lyrics
04/09/2020 11:40:30 [DEBUG] no lyrics found from Teksty
04/09/2020 11:40:30 [WARN] The pattern <div id="div_letra"[^>]*>(?<lyrics>.*?)</div> didn't match!
04/09/2020 11:40:30 [DEBUG] no lyrics found from Letras de músicas
04/09/2020 11:40:30 [WARN] The pattern <p class="mxm-lyrics__content ">\s*(?<lyrics>.*?)</span> didn't match!
04/09/2020 11:40:30 [DEBUG] no lyrics found from Musixmatch
04/09/2020 11:40:31 [DEBUG] gzip compression detected
04/09/2020 11:40:31 [WARN] The pattern <p class="mxm-lyrics__content ">\s*(?<lyrics>.*?)(</span>|<div[^>]*"lyrics-report") didn't match!
04/09/2020 11:40:31 [INFO] No lyrics found.
04/09/2020 11:40:31 [DEBUG] no lyrics found from Musixmatch_Asian
04/09/2020 11:49:37 [DEBUG] Lyrics request: The Blood Brothers - Jordan Billie Pets The Wild Horse’s Mane - This Adultery Is Ripe - Genius
04/09/2020 11:49:37 [INFO] Genius tries to load the lyrics...
04/09/2020 11:49:37 [DEBUG] The constructed URL: http://genius.com/the-blood-brothers-jordan-billie-pets-the-wild-horse-s-mane-lyrics
04/09/2020 11:49:37 [INFO] No lyrics found.
04/09/2020 11:49:37 [DEBUG] no lyrics found from Genius
The part that really bugs me is that lyrics that I can find if I go on Genius' site doing show up when I use it on Musicbee.
OK, I see what might be happening with The Blood Brothers - Jordan Billie Pets The Wild Horse’s Mane - This Adultery Is Ripe.  What are you using in your tags for the apostrophe?
If it's not a true ascii apostrophe - ' -, I don't think it's getting replaced right.  I'm sucky at regex, but I think ' is supposed to get replaced as nothing (bringing horse's together as horses) here.
- [regex, "'", ""]
If it's in your tags as ’ (not an actual apostrophe) then I think it gets replaced with a dash, which is what's happening.
The correct way to account for this is to use actual apostrophes in your tags, but I think you can probably get around this by copying the YML for genius (or whatever other providers) to a local file, adding this...
- [regex, "’", ""]
...to the local YML in both the artist and title sections, putting that YML into your providers folder and using that instead of the built in one.  Worth it to see if that's the actual problem, anyway.
As far as http://www.musixmatch.com/lyrics/764hero/stutter-steps, I have no idea why they strip the - character out of their URL when it's in the actual band name but put in the - character when there's a space in the actual band name.  Doesn't make sense.  The plugin is not set to strip the - character.
I see the built-in (non plug-in) LyricWiki is in your list.  I don't know why it didn't pull lyrics from that, because that site has them, but that's not a plug-in issue.
RetroGameReaper
So I think the problem was mostly because of those special characters. I even got rid of
 - [strip_nonascii, -]
and even the 764-HERO stuff Genius has works. I still don't understand why it won't take the stuff from LyricsWiki though. If anything, I think I'll just start using MediaHuman Lyrics Finder as my means of getting lyrics. Thank you though.
There are providers built-into MB and providers accessible through the plugin.  You can see which providers are searched by the plugin for any given request and which returned results by viewing the plugin's log file in \%APPDATA%\Roaming\MusicBee\mb_LyricsReloaded for the installed version or wherever you have it if you've got a portable install.
