First, thx for all your answers.
Ok, I'll try to explain my problem a little bit better cause I think sense of my whish to skip is misunderstood.
A friend creates chartsplaylists which are very dynamic and change permanently. I.e. a playlist, called "UK Charts 03/25/18". This list contains 50 songs. He gives me an USB-stick with this 50 songs and playlistfile in one folder. Playlist directly link to the files, without folder specification, cause it's in the same folder. Files are named like:
Artist - Title.ext. I'll import that playlist, with this 50 songs renamed to
Artist\Album\Artist - Title.ext and moved to folder
F:\music\ and into my library. That works so far, cause files not exist until yet. Imported playlist linked all songs to new library path correctly. And now, my first world problems begin. Two weeks later he release a new updated playlist called "UK Charts 04/10/18". 5 songs of the previous playlist are not longer contained, 5 new songs get's entry at different chart/playlist positions and other chart/playlist positions will change also. I also get those 50 song files (45 exactly same as 2 weeks ago) and playlist file. Now I want to import this new (updated) playlist, same way, including the 5 new songs.
Now my options are:
Method A: Import the 5 new songs and rebuild the complete playlist manually. Let me think about...no
Want to waste time listening to music, not building chart playlists, which are already done.
Method B: Import/organize new folder including all songs into my music-folder and library, also the 45, which already exist in my library/folder. Check overwrite and overwrite the old files. Results in correct linked path in imported playlist, but not nice, cause all tags of old files, I edited, will be killed. Ok, could backup all tags first and restore them
Method C:
Import/organize new folder including all songs, also the 45, which already exist in my library without overwriting.
Results in duplicates
Artist\Album\Artist - Title_1.ext. I can kill all the dups, but playlist still link to the
*_1.ext files
I can leave the dups, paths are correctly, but waste disk space. Ok, could relink to the older files. But if there must be 20 titles or more has to relink, it's irritating.
Method D:
Import/organize new folder including all songs, and uncheck the existing. Moves new songs renamed into library and link path correct in playlist, but path of the unchecked (older ones) won't link to the existing files in library/music folder. They keep path of the USB-stick.
Method E:
Only importing the 5 new songs, leave the old untouched and change chart/playlist positions manually... see method A
Method F (the one I actually use):
I use foobar and open the playlist, move all songs to
\Music\Artist\Album\Artist - Title.ext on USB-stick and save playlist with updated path/filenames in folder \Music\. Now I move everything including playlist to my music folder, by skipping existing files. So, 5 new songs and playlist will be copied, the other 45 songs will be skipped. Let Musicbee rescan my music and... updated playlist appears and all songs linked correctly and nothings overwritten.
I agree that the current method with duplicating is best for proofing, but I think there should be a fast skip option (like nearly every copy app has) for users, who know what they do (like overwrite option) and want to prevent overwriting of older files, without creating dups. Don't know if I'm the only one, who imports dynamic changing playlists with same songs?!
Best regards
