Author Topic: Remove track# from title?  (Read 1873 times)
NailJ
Hi!
I have a lot of albums where the track number shows up in the title of the song (see picture).
Is there a smarter way than going track by track and editing the title?
I've tried "Auto-tag by album" and this works great but not all my albums are in the databases and so some can't be found, renaming the title from the file does not work because the track number is also in the file name.
Thanks
https://imgur.com/a/d50NS4i
You could use Tools> Tagging Tools> Search and replace command with the following setup if they look all the same (two digits plus a space)
Find: ^.{3}
Title field
Replace: leave it empty
tick regex option.
