I mention this due to memory of some user's hard-to-ID oddities in MusicBee playback being helped by a newer version of this BASS library. Changelog of version 2.4.12 released 2018-03-28:
* BASS_FX:
* Added "Windows Store (Win10-ARM/x86/x64, Win8-x86/x64, Win8-Phone-ARM)" platform support (package bass_fx24-winstore.zip).
* Android, added "arm64-v8a" architecture support (package bass_fx24-android-arm64.zip).
* Linux ARM, added "aarch64" architecture support.
* OSX, removed PowerPC support, since the PowerPC architecture is no longer supported by BASS and Apple.
* Delphi/Pascal, updated BASS_FX.PAS unit and changed "WIN32" to "MSWINDOWS".
* Tempo:
* Updated to the latest SoundTouch version 2.0.0
* Adjusted algorithm parameters to reduce reverberating effect at tempo slowdown.
* Improved sound quality when using integer processing algorithm.
* Improved sound quality when BASS_ATTRIB_TEMPO_OPTION_USE_QUICKALGO == TRUE.
The new quickseek algorithm can find 99% as good results as the default full-scan mode, while the quickseek algorithm is
remarkable less CPU intensive.
* "mixtime" BASS_SYNC_END syncs are delayed until the tempo processing reaches the end (not when the source does), in the
same was as BASS_SYNC_POS syncs.
* Fixed threading issue.
* Miscellaneous small fixes and improvements.
* BPM:
* Reverse:
* Fixed small bug in reverse processing, that BASS_SYNC_END syncs aren't getting triggered on reverse streams that are
playing some files forwards.
* DSP:
* Fixed fRate parameter in BASS_FX_BFX_AUTOWAH effect.
* BASS_FX_BFX_PITCHSHIFT effect is also enabled for Android (armeabi-v7a, x86) and Linux ARM (hardfp), that using now
floating-point instead of fixed-point.
The regular windows version is available at the un4seen site here:
http://www.un4seen.com/download.php?z/0/bass_fx24The "windows store" version mentioned may or may not be relevant to those with MusicBee's "windows store" version, but if you want to try it that one is here:
http://www.un4seen.com/download.php?z/0/bass_fx24-winstore
