Author Topic: Disable clicking through panel  (Read 3144 times)
Tybot
This is not really an issue as all I have to do to avoid it is not to do it, but I'm still curious if there's a way to solve it.
This is my deafult view in TheaterMode, i.e the first thing I see when I launch TheaterMode, pay attention to the tracklist to the right of the cover:
https://i.imgur.com/d8sZjDC.jpg
Now, if I open the lyrics panel, it will overlap the tracklist which means that if I click somewhere in the lyrics panel and that position corresponds to a track in the list in the main panel, the player switches tracks.
https://imgur.com/a/NpNXH
Example: If I open the lyrics panel and click on the word "Leader" (first word, last paragraph) the player switches track 9 "The Times They Are A-Changin'".
Is there a way to disable "onClick="PlayPause"" when another panel is active?
That's expected. Just try not clicking on it. The reason it's been OK is people won't click on lyrics or bio panel.
Tybot
Good to know it's expected. I was messing around with theater mode and happened to click on it so I was just curious. Thanks for the reply!
