Author Topic: MusicBee icons  (Read 56606 times)
butty
icon pack created by ferongr
http://getmusicbee.com/images/icons/iconfiles.zip
Since the change of MusicBee site, MusicBee icons, such as http://getmusicbee.com/images/badges/BeeBadge64.png, have disappeared.
Please give me them again.
Thanks.
Last Edit: November 25, 2011, 06:21:52 AM by Steven
thegreyspot
antiPOP
It is possible to get that icon in higher resolution? 256x256 would be appreciated.
BeeBadge256.png in the same location
antiPOP
Thanks! I've created an icon from this png, which looks much better than default one, coz it's in higher resolution.
butty
Thank you :)
Last Edit: January 24, 2011, 06:40:38 PM by butty
VX
@Moderators
I suggest to move this topic to the Customisations board, so that users could find it easier.
If you don't want to create a separate Icons section, perhaps put it to the Skins until more icon packs for MB are created.
Skins and Icons are stored in the same folder in MB.
there are a number of icons of different sizes in the same folder:
ferongr
Steven, those lack the small note symbol, so they are not exactly the same. Personally I have extracted the normal icon used for the program from the .ico file V4lve posted back then, but I'm not sure on it's license, so I'm wary about remixing/basing works off it.
Also, if V4lve can provide the original PSD, I could start creating different icons for each filetype and create some mockups fairly quickly (compiling them into .ico files with various bitdepths and sizes is the tedious job).
ferongr
Unemployment brings midnight  restlessness and creativity (though it tends to drag on until late morning sometimes, like in this case).
I've been restless and using the icons extracted from the icon file created some early drafts of extension-specific icons. To give make each visually distinct, I decided to replace the color of the wing for each filetype.
For now, 32 pixel versions only since my sleepless mind screwed up and forgot to hide the white background layer during exporting the 256 pixel versions. There are PSDs though so nothing got lost.
V4lve
Hi.  Apologies if this is a bit late but I am not as active here as I was so didn't spot this thread till Steven emailed me.  Here is all my original artwork (including roughs) for the MB Icons and Splash for which I used Powerpoint (believe it of not!) and a zip of all the icons I made..
http://dl.dropbox.com/u/133297/bee.pptx
http://dl.dropbox.com/u/133297/BeeIcons.zip
Last Edit: April 01, 2011, 11:46:11 AM by V4lve
ferongr
