Ah i see, sorry technology was never my best subject, can't wait to try out this Jukebox, looks brilliant.
It's not too difficult to try it out.
You could install a separate portable MusicBee version for testing.
Download the current portable version here:
https://getmusicbee.com/downloads/Select an installation folder somewhere outside the default Windows or Program Files folders.
(it can be on another drive/partition)
Install it.
(when it asks what folder(s) to scan for a library, it would be best if beforehand you had prepared a folder containing some music for these testing purposes, so not to do this testing on your main library)
Then download the alpha version of MB that is mentioned a few posts below (reply #42)
Extract the zipfile, and copy the contents to your new portable MusicBee folder.
It will ask if you want to overwrite a couple of files. Say yes, then start MB and select 'Jukebox' for the main panel view.
