Author Topic: Jukebox view  (Read 49970 times)
I can't get it to work on mine. Shame because it looks fab.
This is only available in the alpha version of 3.4.
beatlesdave270
Ah i see, sorry technology was never my best subject, can't wait to try out this Jukebox, looks brilliant.
It's not too difficult to try it out.
You could install a separate portable MusicBee version for testing.
Download the current portable version here:
https://getmusicbee.com/downloads/
Select an installation folder somewhere outside the default Windows or Program Files folders.
(it can be on another drive/partition)
Install it.
(when it asks what folder(s) to scan for a library, it would be best if beforehand you had prepared a folder containing some music for these testing purposes, so not to do this testing on your main library)
Then download the alpha version of MB that is mentioned a few posts below (reply #42)
Extract the zipfile, and copy the contents to your new portable MusicBee folder.
It will ask if you want to overwrite a couple of files. Say yes, then start MB and select 'Jukebox' for the main panel view.
beatlesdave270
Thank you for that i might give that try once work is finished tomorrow for the weekend. Information much appreciated.
For the next update (not available yet) a different icon will display in place of the play button to indicate clicking it will cue the track.
And an extra skin element that must be defined if you are overriding the colours
Content[Cards].Button.Highlight fg=xxxx
http://www.mediafire.com/file/rkx9mn38mybdpaa/MusicBee.zip/file
You will need to reset the view back to Jukebox.
The fields displayed are now configurable and custom views/ hide panel overrides and assigning the view to playlists/ library filters is now supported.
I am not sold on how these 'play-plus' icons turn out in the wild.
It looks a bit nervous to me:
What about something like this:
To me it looks a bit cleaner and more pleasant to the eye.
It also makes it a lot easier to spot what song is playing.
(try to find the pause icon in the first screenshot)
Last Edit: May 23, 2020, 11:06:34 AM by hiccup
And in case you do consider such a re-design of the icons, I also created a pause icon that I think matches slightly better than the current more 'blocky' one.
(top is current, bottom is new)
download icon
beatlesdave270
Thanks Steven this new Jukebox style is looking brilliant, well done sir.
I dont like the .. after the play button as .. is usually used to indicate a dialog window will open when clicked.
I will trial your suggestion to display the queue button on the left.
Anyone who has views on this or anything about this new view then comments welcome
The symbol for that is the elipsis, and then it would look like this:
But my icon looks like this:
I think the difference is obvious enough.
I do like your new icon better than the old one.
But I feel it is a bit too modern for a 'Jukebox', but that will be a matter of taste of course.
you can now override the queue last icon with this element: "QueueLastIcon"
edit:
i should mention the default icon is 22 x 15 px in size but the override doesnt have to match that
Last Edit: May 24, 2020, 09:21:50 AM by Steven
  • MB Version: 3.6.8800 P
OK then  ;)
The original mock-up had the Artist as the centre line (inside the box) with the track title above. IMHO this looks better is more traditional for jukebox cards.
Although you can change the order of the fields in the customise panel, the first item takes the priority "fg" colour and the second and third line take the "fg2" colour.  The field in the center should have the "fg" and the other two get the "fg2".
How about just having "+⏵" for the cue icon. After all it's literally adding it to the playlist.
Also hiccup's original had grouping by decades. Maybe that could be added.
When you don't have enough tracks to fill all the cards in a row, maybe the row could be padded out with empty cards to increase the "Jukebox" feel.
Otherwise everything else looks great!
Last Edit: May 24, 2020, 08:44:26 AM by Bee-liever
Brilliant
Actually if you scroll to the very end of the list and there is a non-card space, if you try to mouseover the area you get this error
MusicBee v3.4.7449.28439P  (Win10.0), 24 May 2020 17:39:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at #=zkkpe6aq2cTGvxXe62GRsRD520_lh.#=z4GfH4xJB8ASX2ZoHxw==.#=zgbg61BXVapx6tnbvbQAHn04=.OnMouseMove(MouseEventArgs #=z3j2AmnQ=)
   at System.Windows.Forms.Control.WmMouseMove(Message& m)
   at #=z$loG$HLu2YwUD$LWOeQdc$8=.WndProc(Message& #=zo7AEdQQ=)
