Author Topic: scrollwheel very slow for details panel  (Read 924 times)
Alina
When i use the scroll-wheel on the details panel on the right, the lines move very slowly. Much slower than the information in the other panels.
Is there a setting to adjust that?
A good starting point is to say which version you are using.
the latest 3.1 patch version is:
Tybot
I'm experiencing the same thing and I'm using 3.2.6658 and the patch version you posted here: https://getmusicbee.com/forum/index.php?topic=24760.msg143082#msg143082
Scrolling is extremely slow in the "Details" and the newly added "Details (2)" tab. Compared to the "Bio" tab it's like comparing the default scroll mode to the ALT-key mode.
