Author Topic: filter using regex stops working after reboot until I re-save it  (Read 895 times)
cynflux
Hello,
I have a regex filter that displays music files that has explicit lyrics.
The filter stops working after the PC has been rebooted.
I click on the my explicit lyrics filter, but no music files show up.
I click edit filter, but make no changes, and then save, and then music files then show up.
The music files will show up until I reboot the computer.
Once I reboot and run MusicBee again, the filter stops working until I save it again.
I am not sure what is causing this.
MusicBee Portable version 3.1.6590
cynflux
If you go to MusicBee\AppData\Filters folder, you will find the filter file.
Can you post its entire content?
cynflux
I've deleted the filter and created a new filter with the same parameters.
I will let you know if the issue is still there after I reboot.
