Author Topic: Search/Replace  (Read 1320 times)
tangotonyb
Is there a way to do a simple search/replace within a given tag for multiple files?
I have a multi-entry field where I need to change the value of one of the items.
I have the advanced searc/replace plugin, but none of the presets appear to allow you to do this.
Select those files> open tag inspector> find the tag and edit the value> save.
tangotonyb
I cant use Tag Inspector as the files are a mix of mp3s, m4as, flacs, oggs, wavs etc.
Then use MB's native search & replace command after selecting files. On the preview window, you can also deselect certain files to exclude from the change.
tangotonyb
Thank you! - that will save me a lot of grief - I figured the basic Search/Replace functionality HAD to be there, but I couldn't find it!
