Author Topic: MusicBee 3.2  (Read 101105 times)
**** see the last post for the latest update ****
Follow https://twitter.com/MusicBeePlayer for notifications when updates are made available
see the last post for the latest version
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_2_6651.zip
backup:
http://www.mediafire.com/file/ba9c4hnb9mg5y5i/MusicBee_Setup_3_2_6651.zip
- New grid like layout (similar to iTunes) that can be configured in the Album and Tracks view
   https://getmusicbee.com/forum/index.php?topic=24402.0
- Enhanced DSD support for ASIO devices that support raw DSD data or DOP (DSD over PCM)
- New vertical tag editor. This can be configured to display in any side panel and allows you to configure the fields that are editable
  https://getmusicbee.com/forum/index.php?topic=23354.0
- Various new layout options in the Layout(1) preferences
  - Row spacing is now expanded a few pixels but can be configured more or less compressed
  - Custom background image that spans the entire application eg. use http://www.mediafire.com/file/x9166cgtd71d8sa/MusicBee3.jpg on the default MusicBee skin to see an example
    https://getmusicbee.com/forum/index.php?topic=23000.0
  - disable resizing on panels
- You can now save/ load custom layout settings separately for each tab. Right click on a tab header
   https://getmusicbee.com/forum/index.php?topic=21919.0
- You can now save/ load a snapshot of all your settings. See   Edit/ Saved Settings/ ...
- You can now save/ import your panel arrangement - the exported settings are suitable to send to friends. See  View/ Import/Export/ ...
- Virtual tags now support markup (colour, font, contrast) so you can mix the colour used in a single displayed field
   https://getmusicbee.com/forum/index.php?topic=24595.0
- Artwork view now supports grouping by Date Added
- Artwork view now supports sub-grouping using various fields
- Expanded panel in the Artwork view can now be forced to display as a single column
- Relative paths are now supported for artwork retrieval. Set in Layout(1)/ artwork retreival/ Edit List
- Playlists now display a header bar. This can be disabled
- The popup for the playing track now has the option to also popup at the end of a track (so you can rate it)
- You can force the Locked Down mode (in the View menu) to persist on restart
- Compact Player can now be run full screen (set from the menu button on the left of the caption bar)
- You can now directly edit an artist biography in the Artist Bio panel
- When synching lyrics, you can force them to be embedded or synched as a separate .lrc file
- Cut/ Copy/ Paste is now supported for folders in the Computer node of the left navigator
- Custom Tags can now be configured to be enumerated data types. When editing the tag, a drop-down list is displayed with checkboxes making editing easier
   https://getmusicbee.com/forum/index.php?topic=23700.0
- new hotkeys:
  Tools: Auto-Tag by Track - Update Missing Lyrics
  Send To: Active Playlist (now playing)
  Send To: Active Playlist (selected files)
  View: Toggle Show Vertical Tag Editor
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
https://getmusicbee.com/patches/new3.2.txt
Last Edit: January 19, 2019, 05:43:44 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_2_6676.zip
backup:
http://www.mediafire.com/file/rmd34teevjcfobe/MusicBee_Setup_3_2_6676.zip
- The copy tags commands (2 hotkeys and from the main edit menu) now copy all metadata, including tags that MusicBee does not know about. The one exception is for MP3 files, where MusicBee will copy all TXXX tags but wont copy specific 4 character codes it has no handling for such as GEOB.
- new "Bit Depth" field which shows the bits per sample for lossless files. Note that for lossy files (.mp3, .m4a, etc) that its a common mis-understanding that these files have 16-bits per sample when infact its undefined. As such MusicBee shows a blank value for lossy files. You will need to rescan existing lossless files for the value to show (right click/ Send To/ Rescan Files). The value is automatically captured for new files
- when retrieving artwork now has support for Back.jpg files. You will need to enable Back.* in Tags(1)/ artwork storage/ Edit List
- the iTunes export function now exports the playlist folder hierarchy
- when editing multiple files, for "Mixed" fields, the tag editor now has an arrow that allows you to view/ select the tags that are excluded because they are not consistent across all files
- the Expanded Panel settings for the Artwork Layout now allow configuration of the Album header/ sub-header
- when creating new playlists, the name of the playlist is now set in the playlist configuration dialog
- there is now a second track information panel that can be included in the panel arrangement eg. you might dock it as a tab to show secondary track details
- numerous bug fixes
edit:
link updated to fix a couple of bugs
Last Edit: January 19, 2019, 05:43:28 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_2_6693.zip
backup:
http://www.mediafire.com/file/e75q6qru7c1ml7o/MusicBee_Setup_3_2_6693.zip
this is an incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6693.exe
- you can now instruct MusicBee to stop playback at a specific track in the Playing Tracks list. Right click/ Stop After Track
- various improvements to the Now Playing tab
  - you can now have a wavebar displayed
  - the Large Albums view now supports left and right panels for lyrics and artist bio (previously only the right panel could be used)
  - various tweaks to the large album cover layout for different width/ height ratios
- there are now 32 virtual tags available
- editing video files now always saves to the MusicBee database (previously MusicBee would attempt to save tags to .mp4 files, but due to the complexity of some files, that functionality has been disabled)
- the play stop button can now be optionally displayed for standard (non-bitmap) skins - right click on the player panel/ Panel Layout/ Show Stop Button
- various skin element enhancements that will be used by future skins
- fix for playlist retrieval using the sub-sonic plugin
- various other bug fixes
Last Edit: January 19, 2019, 05:43:10 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_2_6721.zip
backup:
http://www.mediafire.com/file/g16j9d0ef5m9jzb/MusicBee_Setup_3_2_6721.zip
this is an incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6721.exe
- right click/ Search/ Find More Artists allows you to search on any of the artists/ guest artists and performers you have associated with the track
- the main player controls panel can now be automatically coloured based on the current playing album cover. This function is only available for standard skins or custom bitmap skins where the author has added support. Right click on the player bar/ Panel Layout/ Auto-Pick Panel Colours
- the Compact Player also allows the player panel to be auto-coloured for all skins
- up to 14 external web-sites can be configured (up from 10)
- you can now right click/ Search/ Open in Web Browser/ ... to open the chosen website using the selected track details
- you can now set a custom background for the main panel only (Edit/ Preferences/ Layout(1)/ main panel/ tick use custom background
- when editing tags, MB will now check the file modification date/time and if its more recent than the value MusicBee has cached, MusicBee will display an alert prompting you to rescan the file
- when synching to devices, the resize artwork to XXX setting now treats the number as a maximum - if the source artwork px size is less than the value then it wont be resized up
- tweaks to improve the layout of the Large Album Covers view in the Playing Tracks panel and Compact Player
translator file - no changes
Last Edit: June 11, 2018, 07:18:06 PM by Steven
First release candidate:
incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6735.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_2_6735.zip
backup:
http://www.mediafire.com/file/7lj3ad5ca64utf3/MusicBee_Setup_3_2_6735.zip
or the full download, including updates to skins and localisations
http://www.mediafire.com/file/42l7kz4ms8rrjb3/MusicBeeSetup_3_2_RC1.zip
portable:
http://www.mediafire.com/file/8midjwrhrmu0ux0/MusicBeePortable_3_2_RC1.zip
Last Edit: June 23, 2018, 06:43:49 PM by Steven
Second and should be final release candidate:
incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6748.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_2_6748.zip
backup:
http://www.mediafire.com/file/7tv2j12l5l2myrg/MusicBee_Setup_3_2_6748.zip
http://www.mediafire.com/file/vy2vav2ecdfy7uz/MusicBeeSetup_3_2_RC2.zip
portable:
http://www.mediafire.com/file/71kabi2cescz3e7/MusicBeePortable_3_2_RC2.zip
Last Edit: July 01, 2018, 02:31:39 PM by Steven
This should be the final 3.2 version, however I will leave it a few days before making it available on the downloads page as it takes a few days for the windows store version to pass validation and be released
full standard install:
http://www.mediafire.com/file/hsmn576gw3lbn03/MusicBeeSetup_3_2.zip
portable install:
http://www.mediafire.com/file/jppdrlj3fe56jcn/MusicBeePortable_3_2.zip
incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6756.exe
http://www.mediafire.com/file/ise2oiqcunlamkv/MusicBee_Setup_3_2_6765.zip
Last Edit: July 05, 2018, 09:33:34 PM by Steven
Unfortunately over the weekend MusicBrainz made a change to the output of one of their APIs that has effectively disabled MusicBee's artist and album picture lookup from fanart.tv, so I am re-releasing MusicBee 3.2. Again I will leave this a few days before making it available on the downloads page
http://www.mediafire.com/file/lf75s4oqdqk7ocz/MusicBeeSetup_3_2_Update1.zip
portable install:
http://www.mediafire.com/file/waeakanah9h7woc/MusicBeePortable_3_2_Update1.zip
incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6760.exe
http://www.mediafire.com/file/x7daja7kjg8bmme/MusicBee_Setup_3_2_6760.zip
Last Edit: August 18, 2018, 03:19:50 PM by Steven
Various bug fixes and minor enhancements:
- mini player now supports a large abum artwork layout
- for regular (non-bitmap) skins, there is better layout support in the main player for when there is a small amount of horizontal width available.
- additionally a stop button can now be displayed for all types of progress bars (regular skins only)
- minor layout tweaks for the "Now Playing" panel
- For the "Album Color Mix" view in the "Now Playing" panel, you can set it to display the artist biography and artist picture
- The Music Explorer panel now allows sorting tracks by title and also shows the album name for duplicate titles
- Playlist header now also shows the album count in the playlist
- when dragging files, the left sidebar no longer automatically pops up (you can hover on the left panel edge and it will pop up)
- in MusicBee v3.2, the bass library changed the default output mode from using DirectSound to WASAPI shared. There are some cases where you will want to use the old DirectSound api (eg. running on Linux with WINE, certain volume controls, etc). You can now instruct MusicBee to use the legacy DirectSound api from the Player preferences
http://www.mediafire.com/file/cto4xsdjm7t1pxj/MusicBeeSetup_3_2_Update2.zip
portable install:
http://www.mediafire.com/file/axq936m4xscdoa3/MusicBeePortable_3_2_Update2.zip
incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6804.exe
http://www.mediafire.com/file/rqd9fv5iyhgrpr9/MusicBee_Setup_3_2_6804.zip
I will leave this a couple of weeks before making it available on the downloads page and windows store release. I will post a new link closer to the time with any new bugs found before then
Last Edit: August 26, 2018, 05:45:18 PM by Steven
An updated version with serveral important bug fixes:
http://www.mediafire.com/file/i17yfo43dzvz41a/MusicBeeSetup_3_2_Update2.zip
portable install:
http://www.mediafire.com/file/pse6gicaqnnvc50/MusicBeePortable_3_2_Update2.zip
incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6826.exe
http://www.mediafire.com/file/ir050zmxixrb4tg/MusicBee_Setup_3_2_6826.zip
Last Edit: September 10, 2018, 06:52:45 PM by Steven
Final planned 3.2 version:
http://www.mediafire.com/file/068i0vp83c65p4w/MusicBeeSetup_3_2_Update2.zip/file
portable install:
http://www.mediafire.com/file/t716c3g5xgl6mz1/MusicBeePortable_3_2_Update2.zip
incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6827.exe
http://www.mediafire.com/file/uas02ibqhevytbh/MusicBee_Setup_3_2_6827.zip
Last Edit: November 24, 2018, 02:45:06 PM by Steven
Because of changes made on the iTunes store api, I have created a updated release for v3.2. It also contains a number of bug fixes since the last official release. This release will be made available on the downloads page in a few days time after the store version has passed validation.
https://www.mediafire.com/file/013558ft0oyuf3b/MusicBeeSetup_3_2_Update3.zip/file
portable install:
https://www.mediafire.com/file/nl8iqge26fjt1cu/MusicBeePortable_3_2_Update3.zip/file
incremental update and includes all changes since version 3.1 - unzip and then run MusicBee_Setup_3_2_6902.exe
https://www.mediafire.com/file/0s97bsb29ahuypv/MusicBee_Setup_3_2_3902.zip/file
The v3.3 beta series has started on this topic:
https://getmusicbee.com/forum/index.php?topic=27074.0
Last Edit: November 24, 2018, 06:04:49 PM by Steven
