Author Topic: "Kommentar unbekannt" - "Comment unknown"  (Read 2752 times)
stardepp
https://drive.google.com/file/d/10O62_L9eVRxGFYRqM240ehoDtOoZVgAd/view?usp=sharing
https://drive.google.com/file/d/1PfKe1N1VQjittts2KxUZiz_VVKJJoTSz/view?usp=sharing
Since the penultimate update to MusicBee 3.2 is in the right sidebar "Kommentar unbekannt" - "Comment unknown", although in the settings window in the column comment is nothing in it. This is the same for all songs where the comma is empty. That bothers me a little.
Can you turn it off somehow?
i expect you are displaying a virtual tag named as comment instead of the actual comment field
stardepp
Of which I have already shown in the first post a screenshot. or where can I find this "the track info panel settings"?
click 'track information' on the right sidebar, 'pane settings' (or 'panel settings').
ok, that is a bug and its fixed for the next v3.2 update
stardepp
Thanks a lot Steven, with this patch version the bug has been fixed.  :)
Best music manager, best forum for that, thanks to you all.
