Author Topic: Win 10 Play Folder with MusicBee  (Read 1730 times)
shinoamakusa
Not sure if this has been reported but using Win 10 Store version folder context menu Play with MusciBee option and gives error
"Windows cannot access the specified device, path or file. You may not have appropriate permissions to access the item."
Non-Store version does not have this issue
martux
I just switched from the Installer version to the store version and also encounter this problem. Already ran MB as Administrator but it doesn't fix. For now the context menus don't work for me with the store version.
