Author Topic: Play tracks by [Genre(s)] from [YYYY] to [YYYY]  (Read 1712 times)
Markus2310
Hey,
Is there any Option to play tracks for example: by Genre: Power Metal released from 2010 to 2014? Or play only tracks from 1990 to 1999 with Genre Eurodance from Germany?
that would be really awesome ^.^
cjoprey
  • MB Version: 3.4
Press "Ctrl-F" for the custom search box. Make sure the match dropdown is set to "all", and then enter the following rules:
- "Genre" "contains" <your genre>
- "Year" "is after" <start year>
- "Year" "is before" <end year>
Hope that helps!
Markus2310
oohh, there is a searchbox  :-[  ;D
thanks, that helped a lot!
Freddy Barker
  • 🎧 MB 3.4.7628P
Hey,
You could also use an Auto-playlist. .
Music track source: Library (music library)
 Display using view: Default
 Match: ALL of the following rules
 Year is less than 2014
 Year is greater than 2010
 Genre contains Metal
 Shuffle: Random
 Select by: Track
 Automatically refresh the matching tracks
Regards: Freddy
Hey,
 Shuffle: Random
 Select by: Track
Regards: Freddy
It's even less complicated than that:
Year (yyyy) -> in range -> 1990 -> 1999
You can even do
Decade is 1990s
I love auto-playlists!
