Author Topic: 16/24bit depth column  (Read 12777 times)
Alumni
As this has come up quite often, i have now added database support for bit depth.
The value will be automatically saved for new files, but for your existing files, you will need to rescan them (right click/ Send To/ Rescan Files)
The new "Bit Depth" field can be displayed, sorted, filtered as any field
http://musicbee.niblseed.com/V3_2/MusicBee32_Patched.zip
A very welcome addition, thanks for adding this!
CritterMan
  • Now with FiiO M11!
I've found a couple of uses. Pairs nicely with sample rate.
Since no human could hear the difference between 16 and 24 bit without deafening themselves in the process, it'll be helpful to have a visual clue to see if any files are wasting the space.  ;D
Seriously, though, happy for those who wanted it.
  • MB Version: 3.6.8849 P
@ Steven
Thanks for doing this but I do have a minor issue.
After rescanning my library, I noticed my lossy compression files (mp3, aac, etc) are all showing a bit depth of 16.
As no lossy compression format has an associated bit depth, shouldn't they be blank or have N/A?
While you are correct, i felt most users wont know that and have the idea that its 16-bit. So less "bug" reports if its stated as 16-bit
CritterMan
I hadn't noticed that since I have such a small amount of lossy content. Audacity refers to MP3 and AAC files as "32-bit float." I suppose that's as accurate a description as any. But I really don't know if there's an industry standard. "Float" might be a good option, but I suspect the goal with this implementation is to keep the value down to two characters for nice, thin columns. I'd like suggest " 8) " and " ::) " as alternatives.
Well i could change it to display "?" which is what foobar does. I still cant help feeling thats going to cause confusion to most people though.
If i did that, MB would treat the value as -1 in terms of sorting
For me both mp3tag and foobar show nothing for lossy format files when the field is added to a column.
I think MB could do the same thing.
for the next update i have changed it to show blank for lossy files. The value for filtering/ sorting purposes is 0
Last Edit: April 01, 2018, 05:16:32 PM by Steven
CritterMan
No matter what you do, you're going to get people telling you it's wrong. At least this way, you're not giving a false answer and they'll be separate from actual 16 bit depth files for sorting.
ost
Hmm, before last update all my mp3 and m4a files was showing correct bit depth - 16 bit. Now it's Unknown Bit Depth  :-\
the change made is technically correct in that lossy files have an undefined bit-depth. But i suspect most people dont know that and think its 16-bit. I will leave it a day to allow for other's comments but i am inclined to revert it to show 16 bit for lossy files
ost
I think that "16 bit" looks better than "Unknown Bit Depth" even if it's not correct.
