Author Topic: Color & font size format function  (Read 18103 times)
@Steven- is this enabled for the expanded view of artwork? If not, can it please be added to your list of requests?
Thanks.
Last Edit: November 19, 2018, 07:10:30 PM by phred
DP
The fonts are logical and work solidly. But visually they can get lost in black and white on the screen. Would it involve too much overhead to implement a color option (just basics) for the Track Information fields?
Or even, though maybe less critical, for other text fields in the layout?
Thanks.
apokal
Italic style is not allowed i guess? Because this doesn't work for me. Do you know why? I've tried on Track Information Panel.
{font: Segoe UI;italic;9,75}
working fine here except i needed to use:
{font: Segoe UI;italic;9.75}
apokal
Other styles works fine. What is the problem you think? I'm using the latest version.
Looks to me like the number is just not localized, so use . instead of , as a separator.
apokal
I don't think it's a format issue.
No problem with these:
{font: Segoe UI;Regular;9,75}
{font: Segoe UI;Bold;9,75}
{font: Arial;Regular;9,75}
{font: Arial;Bold;12}
there is something wrong with italic thing:
Did you try Steven's and psychoadept's suggestion of changing the comma to a period in the font size?
apokal
Yes. Nothing changed.
apokal
Problem solved.
{font: Segoe UI;ıtalic;9.75}
My OS language is Turkish. I've changed italic to ıtalic.. "ı" is a letter of Turkish alphabet. Now all problems are gone.  ;)
johnmillsjr
Thanks.
I'm having issues bolding A tag in a virtual tags in Album Covers View as well. No font arguments get applied to Album Covers View- even when 'Use custom Font' is unchecked
johnmillsjr
Is something like this possible? it doesn't change the fonts at all
