Author Topic: iTunes Library  (Read 1219 times)
mazarron
Hello,
I just want to import all my songs from iTunes to Musicbee but all I get when I try is ''iTunes music library.xml file not found''
It can't be that difficult surely. Any suggestions anyone.
Many thanks.
Freddy Barker
  • 🎧 MB 3.4.7628P
Hello,
Many thanks.
That xml file may need to be generated and exported using itoons..
Help should be here:-
http://musicbee.wikia.com/wiki/Importing
Freddy
Last Edit: March 02, 2018, 10:37:01 PM by Freddy Barker [DIVERSITY FM]
MTVhike
I found an old iTunes library and tried importing it. MB did find the .XML file and imported the library, but there are essentially no tags. When I tried to "set displayed fields", there were no "Other Fields". I can play the content using iTunes, however, and all the fields are there.
