Author Topic: "Copy all metadata" command  (Read 6459 times)
Can you expand this functionality to format converter too?
Currently if you convert a file either to the same or a different format, only tags known to MB are copied to the new file.
To copy entire tags including unmapped tags, you have to run copy and paste tags command after conversion. But it's not possible when replace original file option is selected. Or this could be offered as an option.
If it's implemented, this should copy RG tags as well unlike copy tags command.
wombleywoo
If anyone is interested, I have created a crowdfunding campaign to pay a developer to make a plugin which automates this process!
https://gofund.me/38c41b2e
