Author Topic: MusicBee Portable  (Read 4984 times)
Existence
Hello.
How can I uninstall MusicBee portable?
Please can anyone help?
CritterMan
  • Now with FiiO M11!
Click once on the MusicBee folder where your portable installation resides. Press your delete key. Profit.
cynflux
How does one update a portable installation of MusicBee?
I got a notification that there was an update available.
Thank you in advance.
Assuming you mean the 3.1 Update 3 version, go to the last link displayed in the message here:
https://getmusicbee.com/forum/index.php?topic=21135.msg139200#msg139200
Download the zip, extract MusicBeePortable_3_1_Update3.exe, run it, let it do its thing.
After you do that, you are well advised to also apply the latest patch for 3.1, which you can get here:
http://musicbee.niblseed.com/V3_1/MusicBee31_Patched.zip   (extract the contents into your MusicBee folder and allow it to overwrite existing files)
