Author Topic: Recent issues with the getmusicbee.com website  (Read 10713 times)
A couple of days ago the host for the getmusicbee.com website upgraded the OS version. Unfortunately the SSL certificate was messed up and additionally a script incompatibility took the site down. Thats now fixed.
But there is still an ongoing issue where you will occassionally see a "500 Internal Error".
It has been reported but so far the solution they provided hasn't worked
Thank you Steven for keeping us up to date on the situation.
I put a notice up on the wiki, directing people to Twitter if they're unable to access the website.  Hope it gets resolved!
FYI, as of now I have stopped getting the "500 Internal Error" messages that were the norm earlier today, hopefully that means the fix is in!
Last Edit: February 25, 2018, 12:16:07 AM by sveakul
AvikB
As for now the site is using cloudflare for cache CDN. But there are new problems, some pages do not work. forum seems intact though. so thats a good sign.
Hopefully we will have a working solution in few days or so.
Apparantly it can take up to 2 days for the cloudfare configuration to propogate, and hence some people will experience SSL secure connection failures. I've experienced this a few times myself but eventually get through
All the issues with cloudfare should now be resolved.
While the "500 Internal Error" issue has much improved, I am finding it still happens sometimes. In the next month or so, AvikB is planning to make a change that should help further.
Alumni
I'm seeing a lot of error messages when browsing the forum, not very usable at the moment.
What type of error messages?
i very very very frequently see '500 internal error' message. but refreshing a page always helps.
Yeah, I'm still getting the Internal Server Error message fairly often.  There will be long spells without it, and then it shows up again. (Appropriately, even when I posted this message!)
Yes, me too. Especially today more than yesterday. But as boroda74 said, a refresh clears it. Still ... it shouldn't be.
AvikB
The new Hosting server OS update seems to broke some stuff along with this annoyance.
I am working on a major update for the website backend, specially caching that should reduce server resource usage. Hopefully this might solve it.
According to Steven this problem started with SMF 2.0, before the new website was even introduced. There was a temporary fix for this back then, but with the new server update it is not compatible anymore.
I am looking into it, will let you guys know if a proper fix is possible or not.
Freddy Barker
  • 🎧 MB 3.4.7628P
